Salta al contenuto principale
Dell Chromebook 13-7310 Cooling Fan Replacement
Cosa ti serve
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 2 di 2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: passo 4, immagine 1 di 2 Dell Chromebook 13-7310 Cooling Fan Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Conclusione
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 501
