Salta al contenuto principale
Dell Chromebook 13-7310 Battery Replacement
Cosa ti serve
  1. Dell Chromebook 13-7310 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Chromebook 13-7310 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Battery Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Battery Replacement: passo 5, immagine 1 di 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
Conclusione
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,256
