Introduzione
In this guide we will show you how to properly, and safely, remove and replace your laptops track pad.
Cosa ti serve
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Using a pointed metal spudger, pull the tiny switch on top of the ribbon cable port away from the wire insertion to unlock it. Then gently remove the ribbon cable that connects the trackpad to the motherboard.
Altre 2 persone hanno completato questa guida.
