Salta al contenuto principale
Dell Chromebook 11-3120 Bottom Base Cover Replacement
Cosa ti serve
  1. Dell Chromebook 11-3120 Bottom Base Cover Replacement, Remove screws: passo 1, immagine 1 di 1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Bottom Base Cover Replacement: passo 2, immagine 1 di 2 Dell Chromebook 11-3120 Bottom Base Cover Replacement: passo 2, immagine 2 di 2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
Conclusione
Dalton D
Membro da: 12/08/17
2.534 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 299
