Introduzione
This guide will help you replace the battery of a Dell Chromebook 11-3120. Please have a safe, static-free place where you can place the battery after it has been removed from the device.
Cosa ti serve
Flip the device over so the bottom is facing up
Remove the 7 visible Philips screws from the device's bottom cover
Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
