Salta al contenuto principale
Dell Chromebook 11-3120 Battery Replacement
Cosa ti serve
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: passo 1, immagine 1 di 1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: passo 2, immagine 1 di 2 Dell Chromebook 11-3120 Battery Replacement: passo 2, immagine 2 di 2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: passo 3, immagine 1 di 1
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: passo 4, immagine 1 di 1
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
Conclusione
Dalton D
Membro da: 12/08/17
2.534 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 375
