Introduzione
When looking to repair your Dell Chromebook 11-3120, you must follow these instructions to remove the back panel of the device where the internal hardware resides. Once this is accomplished, you will have full access to the hardware inside your device. You will need a #J0 Philips screwdriver to remove the seven screws on the panel assembly.
Cosa ti serve
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Altre 4 persone hanno completato questa guida.
