Salta al contenuto principale
Dell Chromebook 11-3120 Back Panel Replacement
Cosa ti serve
  1. Dell Chromebook 11-3120 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Dell Chromebook 11-3120 Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
  2. Dell Chromebook 11-3120 Back Panel Replacement: passo 2, immagine 1 di 2 Dell Chromebook 11-3120 Back Panel Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to gently pry around the four sides of the back panel until the panel is fully released.
    • Taking the back cover off of the computer may require more force than expected. When using the opening tool, be careful not to use too much force on it, and make sure all the screws are removed.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 17
Tutti i Tempi: 556
