Salta al contenuto principale
Dell Chromebook 11 CB1C13 DC Jack Cable Replacement
Cosa ti serve
    • Get your trusty Phillips screwdriver and unscrew the Phillips Screws and put them somewhere safe.
    • Then pry open and remove bottom case cover.
    • Now what you want to do is find two screws protecting the battery. Unscrew them and put them somewhere safe.
    • Remove the cable from the battery and put it somewhere safe.
    • Now, find the DC Jack Cable. It should be in the top right corner.
    • To remove the DC Jack Cable, use your fingernails and try to remove it. Once out, put it somewhere safe.
    • To put in a new one, insert it with a lot of pressure and it should be secure.
Conclusione
To reassemble your device, follow steps 1 and 2 in reverse order.
EmreTech
Membro da: 05/12/18
190 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 108
