Salta al contenuto principale
Dell Chromebook 11 CB1C13 Battery Replacement
Cosa ti serve
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: passo 1, immagine 1 di 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: passo 1, immagine 2 di 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: passo 2, immagine 1 di 2 Dell Chromebook 11 CB1C13 Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: passo 3, immagine 1 di 2 Dell Chromebook 11 CB1C13 Battery Replacement: passo 3, immagine 2 di 2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
Conclusione
To replace your Dell Chromebook 11 battery, follow these instructions in order.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,350
