Salta al contenuto principale
Dell Chromebook 11 3189 Display Assembly Replacement
Cosa ti serve
  1. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Display Hinge: passo 1, immagine 1 di 1
    • Lift the display assembly away from the computer.
  2. Dell Chromebook 11 3189 Display Assembly Replacement, Place the Display Assembly: passo 3, immagine 1 di 1
    • Place the display assembly to align with the screw holders on the computer.
  3. Dell Chromebook 11 3189 Display Assembly Replacement, Replace the Screws: passo 4, immagine 1 di 1
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  4. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Sensor Cable: passo 5, immagine 1 di 1
    • Flip over the computer and connect the sensor cable on the system board.
  5. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the Display Cable: passo 6, immagine 1 di 1
    • Connect the display cable to the connector on the system board.
  6. Dell Chromebook 11 3189 Display Assembly Replacement, Securing the Screws: passo 7, immagine 1 di 1
    • Place the metal bracket over the (display cable) connector, and tighten the M2.0x3.0 screws to secure the display cable to the computer.
  7. Dell Chromebook 11 3189 Display Assembly Replacement, Connecting the WLAN cables.: passo 8, immagine 1 di 1
    • Connect the WLAN cables.
  8. Dell Chromebook 11 3189 Display Assembly Replacement, Placing the Metal Bracket: passo 9, immagine 1 di 1
    • Place the metal bracket, and tighten the M2.0x3.0 screw to the WLAN cable on the system board.
Conclusione
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
Un commento
Hola, he remplazado la pantalla. El montaje perfecto pero no enciende. Hay que hacer algo en concreto? Me refiero para que detecte esta pantalla nueva.
Muchas gracias
jordi fernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,794
