Introduzione
In this guide, we will show you how to remove and replace the Memory Modules.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your  computer and follow the steps in Before You Begin. CAUTION: To prevent damage to the memory-module connector, do  not use tools to spread the memory module securing clips. Using your fingertips, spread apart the  securing clips on each end of the memory-module connector until the memory module pops up.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Remove the memory module from the memory-module connector. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. NOTE: If you need to install memory modules in two connectors, install a memory  module in the lower connector before you install a memory module in the upper  connector. Align the notch on the NEW memory module  with the tab on the memory-module  connector.
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  5. Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Conclusione
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 47
