Introduzione
In this guide, we will show you how to remove and replace the Hard Drive.
Parti
Nessuna parte richiesta.
  1. WARNING:  Before working inside your computer, read the safety information  that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
  2. Using the pull-tab, lift the hard-drive assembly to disconnect it from the  connector on the system board.
    • Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
  3. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
  4. Remove the four screws that secure the hard drive to the hard-drive  bracket.
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Lift the hard-drive off the hard-drive bracket.
    • Lift the hard-drive off the hard-drive bracket.
  7. Remove the interposer from the hard drive.
    • Remove the interposer from the hard drive.
  8. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  9. Place the hard drive in the hard-drive bracket. Place the hard drive in the hard-drive bracket.
    • Place the hard drive in the hard-drive bracket.
  10. Replace the four screws that secure the hard drive to the hard-drive  bracket.
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  11. Align the connector on the hard drive with the connector on the system  board and press the hard drive until it is fully seated.
    • Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
  12. Tighten the three captive screws that secure the hard-drive assembly to the  computer base.
    • Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Conclusione
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 155
