Introduzione
In this guide, we will be showing you how to remove and replace the Memory Modules.
Parti
Nessuna parte richiesta.
  1. WARNING:   Before   working   inside   your   computer,   read   the   safety  information that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Loosen the captive screw that secures the memory-module door to the computer base.
  2. Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
    • Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
    • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
    • Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
    • Remove the memory module.
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch on the NEW memory module with the tab on the memory module connector.
    • Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
    • CAUTION: If the memory module door is difficult to close, remove the memory module and reinstall it. Forcing the memory module door to close may damage your computer.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Conclusione
Terrence15
Membro da: 18/12/2017
70.228 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 70
