Salta al contenuto principale
Dell Alienware M17x R2 Display Assembly Replacement
Cosa ti serve
  1. Dell Alienware M17x R2 Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid damage to the display, you must not disassemble your Edge-to-Edge display assembly.
    • Remove the four screws (two from each hinge) that secure the display assembly to the computer base.
  2. Dell Alienware M17x R2 Display Assembly Replacement, Lifting the Display Assembly: passo 2, immagine 1 di 1
    • Bend the display assembly towards the computer base at a 45-degree angle and lift the display assembly off the computer.
  3. Dell Alienware M17x R2 Display Assembly Replacement, Align the Screw Holes: passo 3, immagine 1 di 1
    • Align the screw holes on the display hinges with the computer base.
  4. Dell Alienware M17x R2 Display Assembly Replacement, Replace the Screws: passo 4, immagine 1 di 1
    • Replace the four screws (two on each hinge) that secure the display assembly to the computer base.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,360
