Salta al contenuto principale
Dell Alienware M11x R3 2.5" Hard Drive Replacement
Cosa ti serve
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: passo 1, immagine 1 di 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: passo 1, immagine 2 di 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: passo 1, immagine 3 di 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Remove the three screws attaching the hard drive tray to the laptop.
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: passo 3, immagine 1 di 1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: passo 4, immagine 1 di 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: passo 4, immagine 2 di 2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: passo 5, immagine 1 di 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: passo 5, immagine 2 di 2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,546
