Salta al contenuto principale
Dell Alienware 18 Memory Module Replacement
Cosa ti serve
  1. Dell Alienware 18 Memory Module Replacement, Warning: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    Chiedi a FixBot
  2. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: passo 2, immagine 1 di 1
    • To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
    Chiedi a FixBot
  3. Dell Alienware 18 Memory Module Replacement, Popping up the Memory Module: passo 3, immagine 1 di 1
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    Chiedi a FixBot
  4. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: passo 4, immagine 1 di 1
    • Remove the memory module from the memory-module connector.
    Chiedi a FixBot
  5. Dell Alienware 18 Memory Module Replacement, Replacing the Memory Module: passo 5, immagine 1 di 1
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
    Chiedi a FixBot
  6. Dell Alienware 18 Memory Module Replacement, Securing the Memory Module: passo 6, immagine 1 di 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    Chiedi a FixBot
Linea Traguardo
Altre 2 persone hanno completato questa guida.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.002 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 92
Tutti i Tempi: 765
