Salta al contenuto principale
Dell Alienware 18 Display Assembly Replacement
Cosa ti serve
  1. Dell Alienware 18 Display Assembly Replacement, Closing the Display: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin
    • Close the display and turn the computer over.
  2. Dell Alienware 18 Display Assembly Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Alienware 18 Display Assembly Replacement, Open the Display: passo 3, immagine 1 di 1
    • Turn the computer over and open the display.
  4. Dell Alienware 18 Display Assembly Replacement, Disconnecting the Video-Card Connector: passo 4, immagine 1 di 1
    • Disconnect the video-card connector cable from its connector on the system board.
  5. Dell Alienware 18 Display Assembly Replacement, Disconnecting the Display Cable: passo 5, immagine 1 di 1
    • Pull the pull-tab to disconnect the display cable from its connector on the system board.
  6. Dell Alienware 18 Display Assembly Replacement, Disconnecting the LED-Logo Board Cable: passo 6, immagine 1 di 1
    • Disconnect the LED-logo board cable from its connector on the system board.
  7. Dell Alienware 18 Display Assembly Replacement, Disconnecting the Antenna Cables: passo 7, immagine 1 di 1
  8. Dell Alienware 18 Display Assembly Replacement, Removing the Cables: passo 8, immagine 1 di 1
    • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
  9. Dell Alienware 18 Display Assembly Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Remove the screw that secures the routing guides to the computer base.
  10. Dell Alienware 18 Display Assembly Replacement, Lifting the Routing Guides: passo 10, immagine 1 di 1
    • Slide and lift the routing guides off the computer base.
  11. Dell Alienware 18 Display Assembly Replacement, Remove the Screws: passo 11, immagine 1 di 1
    • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
  12. Dell Alienware 18 Display Assembly Replacement, Lifting the Display Assembly: passo 12, immagine 1 di 1
    • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
  13. Dell Alienware 18 Display Assembly Replacement, Placing the Display Assembly: passo 13, immagine 1 di 1
    • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
  14. Dell Alienware 18 Display Assembly Replacement, Replace the Screw: passo 14, immagine 1 di 1
    • Place the routing guides on the computer base and replace the screw that secures the routing guides to the computer base.
  15. Dell Alienware 18 Display Assembly Replacement, Route the Mini-card: passo 15, immagine 1 di 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  16. Dell Alienware 18 Display Assembly Replacement, Connecting the Display Cable: passo 16, immagine 1 di 1
    • Connect the Mini-Card antenna cables to the Mini-Card. See"Replacing the Wireless Mini-Card" on page 107.
    • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
  17. Dell Alienware 18 Display Assembly Replacement, Close the Display: passo 17, immagine 1 di 1
  18. Dell Alienware 18 Display Assembly Replacement, Replace the Screws: passo 18, immagine 1 di 1
    • Replace the screws that secure the display assembly to the computer base.
Linea Traguardo
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.993 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 954
