Introduzione
In this guide, we will be showing you how to remove and replace the Coin-Cell Battery.
Parti
Nessuna parte richiesta.
  1. WARNING:   Before working inside your computer, read the safety information that shipped with your  computer and follow the steps in Before     You     Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Slide the base cover towards the rear of  the computer and lift it off the computer  base.
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Align the tabs on the NEW base cover with the  slots on the computer base and slide the  base cover into place.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Replace the screws that secure the base cover to the computer base.
    • Replace the screws that secure the base cover to the computer base.
  7. WARNING: Before working inside your computer, read the safety  information that shipped with your  computer and follow the steps in Before You Begin.
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  8. Remove the coin-cell battery cable from the routing guides on the computer base.
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  9. Pry up the coin-cell battery from  the slot on the system board.
    • Pry up the coin-cell battery from the slot on the system board.
  10. Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer  base.
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  11. Route the coin-cell battery cable through the routing guides on the computer base.
    • Route the coin-cell battery cable through the routing guides on the computer base.
  12. Connect the coin-cell battery cable to  its connector on the system board.
    • Connect the coin-cell battery cable to its connector on the system board.
Linea Traguardo
darrius
Membro da: 26/03/2018
5.072 Reputazione
30 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 62
