Salta al contenuto principale
Dell Alienware 18 Battery Pack Replacement
Cosa ti serve
  1. Dell Alienware 18 Battery Pack Replacement, Before You Begin: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Battery Pack Replacement, Remove the base cover screws: passo 2, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Battery Pack Replacement, Slide the Cover: passo 3, immagine 1 di 1
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Battery Pack Replacement, Prelude: passo 4, immagine 1 di 1
  5. Dell Alienware 18 Battery Pack Replacement, Remove the battery screws: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two screws securing the battery to the computer base.
  6. Dell Alienware 18 Battery Pack Replacement, Disconnect the battery cable: passo 6, immagine 1 di 1
    • Disconnect the battery cable from its connector by pulling it straight up from its socket.
  7. Dell Alienware 18 Battery Pack Replacement, Remove the battery: passo 7, immagine 1 di 1
    • Remove the battery from its recess.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
Un commento
This is the wrong computer being displayed here.
Tru-B -DaT - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,194
