Salta al contenuto principale
Dell Alienware 15 R3 Battery Replacement
Cosa ti serve
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: passo 1, immagine 1 di 3 Dell Alienware 15 R3 Battery Replacement, Back Case: passo 1, immagine 2 di 3 Dell Alienware 15 R3 Battery Replacement, Back Case: passo 1, immagine 3 di 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Battery Replacement: passo 2, immagine 1 di 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Battery Replacement: passo 4, immagine 1 di 2 Dell Alienware 15 R3 Battery Replacement: passo 4, immagine 2 di 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Battery Replacement: passo 5, immagine 1 di 3 Dell Alienware 15 R3 Battery Replacement: passo 5, immagine 2 di 3 Dell Alienware 15 R3 Battery Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
  7. Dell Alienware 15 R3 Battery Replacement: passo 7, immagine 1 di 3 Dell Alienware 15 R3 Battery Replacement: passo 7, immagine 2 di 3 Dell Alienware 15 R3 Battery Replacement: passo 7, immagine 3 di 3
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 279
Tutti i Tempi: 5,445
