Introduzione
In this guide, we will be showing you how to remove and replace the memory modules.
Cosa ti serve
Remove the screws that secure the base cover to the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
Replace the screws that secure the base cover to the computer base.
Disconnect the battery cable from the system-board connector.
Using the battery cable, lift the battery and release it from the tabs on the computer base.
Turn the computer over and open the display as far as possible.
Press and hold the power button for five seconds to ground the system board.
Align the tabs on the NEW battery with the slots on the computer base.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the screws that secure the battery to the computer base.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
