Salta al contenuto principale
Dell Alienware 13 Touch pad Replacement
Cosa ti serve
  1. Dell Alienware 13 Touch pad Replacement, Base Panel: passo 1, immagine 1 di 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Touch pad Replacement: passo 2, immagine 1 di 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Touch pad Replacement: passo 3, immagine 1 di 3 Dell Alienware 13 Touch pad Replacement: passo 3, immagine 2 di 3 Dell Alienware 13 Touch pad Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    Compra
  4. Dell Alienware 13 Touch pad Replacement, Touch pad: passo 4, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement, Touch pad: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the battery cable terminal.
  5. Dell Alienware 13 Touch pad Replacement: passo 5, immagine 1 di 1
    • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
  6. Dell Alienware 13 Touch pad Replacement: passo 6, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement: passo 6, immagine 2 di 2
    • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
  7. Dell Alienware 13 Touch pad Replacement: passo 7, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement: passo 7, immagine 2 di 2
    • Using the pull tab, disconnect the black solid-state drive cable from the system board.
  8. Dell Alienware 13 Touch pad Replacement: passo 8, immagine 1 di 1
    • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
  9. Dell Alienware 13 Touch pad Replacement: passo 9, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement: passo 9, immagine 2 di 2
    • Lift up on the solid-state drive assembly to remove it from the computer base.
  10. Dell Alienware 13 Touch pad Replacement: passo 10, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement: passo 10, immagine 2 di 2
    • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
  11. Dell Alienware 13 Touch pad Replacement: passo 11, immagine 1 di 3 Dell Alienware 13 Touch pad Replacement: passo 11, immagine 2 di 3 Dell Alienware 13 Touch pad Replacement: passo 11, immagine 3 di 3
    • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
    • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
    • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
  12. Dell Alienware 13 Touch pad Replacement: passo 12, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement: passo 12, immagine 2 di 2
    • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
  13. Dell Alienware 13 Touch pad Replacement: passo 13, immagine 1 di 3 Dell Alienware 13 Touch pad Replacement: passo 13, immagine 2 di 3 Dell Alienware 13 Touch pad Replacement: passo 13, immagine 3 di 3
    • Turn the computer over and open the display as far as possible.
    • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
    • Gently lift the palm-rest assembly.
  14. Dell Alienware 13 Touch pad Replacement: passo 14, immagine 1 di 3 Dell Alienware 13 Touch pad Replacement: passo 14, immagine 2 di 3 Dell Alienware 13 Touch pad Replacement: passo 14, immagine 3 di 3
    • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
    • Lift the palm-rest assembly off the computer base.
  15. Dell Alienware 13 Touch pad Replacement: passo 15, immagine 1 di 2 Dell Alienware 13 Touch pad Replacement: passo 15, immagine 2 di 2
    • Disconnect the touch pad cable from the touch pad.
  16. Dell Alienware 13 Touch pad Replacement: passo 16, immagine 1 di 3 Dell Alienware 13 Touch pad Replacement: passo 16, immagine 2 di 3 Dell Alienware 13 Touch pad Replacement: passo 16, immagine 3 di 3
    • Remove (4) 3 mm Phillips head screws securing the touch pad to the palm rest assembly using a Phillips # 0 screwdriver.
    • Lift up and remove the touch pad from the palm rest assembly.
Conclusione
USF Tampa, Team 14-2, Eyestone Fall 2016 Membro di USF Tampa, Team 14-2, Eyestone Fall 2016
USFT-EYESTONE-F16S14G2
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 335
