Introduzione
In this guide, we will be showing you how to remove and replace the Solid-State Drive.
Strumenti
Parti
Nessuna parte specificata.
Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
Using the pull tab, disconnect the solid-state drive cable from the system board.
Remove the screws that secure the solid-state drive assembly to the computer base.
Lift the solid-state drive assembly off the computer base.
Make sure the screws are off the solid-state assembly.
Slide the new solid-state drive into the solid-state drive assembly.
Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
Replace the screws that secure the solid-state drive assembly to the computer base.
Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Un commento
Hi there. Could I have a link to the full service manual you got this from? Thanks.
