Salta al contenuto principale
Dell Alienware 13 R3 Wireless Card Replacement
Cosa ti serve
  1. Dell Alienware 13 R3 Wireless Card Replacement, Loosen the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Wireless Card Replacement, Pry the Base Cover: passo 2, immagine 1 di 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Wireless Card Replacement, Lift the Base Cover: passo 3, immagine 1 di 1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Wireless Card Replacement, Disconnect the Battery Cable: passo 4, immagine 1 di 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Wireless Card Replacement, Slide the Tabs: passo 7, immagine 1 di 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Wireless Card Replacement, Tighten the Five Captive Screws: passo 8, immagine 1 di 1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Wireless Card Replacement, Align the Notch: passo 9, immagine 1 di 1
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
  8. Dell Alienware 13 R3 Wireless Card Replacement, Lift the Wireless-Card Bracket: passo 10, immagine 1 di 1
    • Lift the wireless-card bracket off the wireless card.
  9. Dell Alienware 13 R3 Wireless Card Replacement, Disconnecting the Antenna Cables: passo 11, immagine 1 di 1
    • Disconnect the antenna cables from the wireless card.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
    • Slide the NEW wireless card at an angle into the wireless-card slot.
    • Connect the antenna cables to the wireless card.
  10. Dell Alienware 13 R3 Wireless Card Replacement, Align the Screw Hole: passo 15, immagine 1 di 1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
  11. Dell Alienware 13 R3 Wireless Card Replacement, Replace the Screw: passo 16, immagine 1 di 1
    • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
Conclusione
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 896
