Salta al contenuto principale
Dell Alienware 13 R3 Rear-I/O Cover Replacement
Cosa ti serve
  1. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Loosen the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Pry the Base Cover: passo 2, immagine 1 di 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Lift the Base Cover: passo 3, immagine 1 di 1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Disconnect the Battery Cable: passo 4, immagine 1 di 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Slide the Tabs: passo 7, immagine 1 di 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Tighten the Five Captive Screws: passo 8, immagine 1 di 1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  8. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Using a Plastic Scribe: passo 10, immagine 1 di 1
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  9. Dell Alienware 13 R3 Rear-I/O Cover Replacement, Sliding the Rear-I/O: passo 12, immagine 1 di 1
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Conclusione
Terrence15
Membro da: 12/18/17
79.309 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 845
