Salta al contenuto principale
Dell Alienware 13 R3 Display Panel Replacement
Cosa ti serve
  1. Dell Alienware 13 R3 Display Panel Replacement, Loosen the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Display Panel Replacement, Pry the Base Cover: passo 2, immagine 1 di 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Display Panel Replacement, Lift the Base Cover: passo 3, immagine 1 di 1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Display Panel Replacement, Disconnect the Battery Cable: passo 4, immagine 1 di 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Display Panel Replacement, Slide the Tabs: passo 7, immagine 1 di 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Display Panel Replacement, Tighten the Five Captive Screws: passo 8, immagine 1 di 1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Display Panel Replacement, Align the Notch: passo 9, immagine 1 di 1
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
  8. Dell Alienware 13 R3 Display Panel Replacement, Lift the Wireless-Card Bracket: passo 10, immagine 1 di 1
    • Lift the wireless-card bracket off the wireless card.
  9. Dell Alienware 13 R3 Display Panel Replacement, Disconnecting the Antenna Cables: passo 11, immagine 1 di 1
    • Disconnect the antenna cables from the wireless card.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
    • Slide the NEW wireless card at an angle into the wireless-card slot.
    • Connect the antenna cables to the wireless card.
  10. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Hole: passo 15, immagine 1 di 1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
  11. Dell Alienware 13 R3 Display Panel Replacement, Replace the Screw: passo 16, immagine 1 di 1
    • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
  12. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screw: passo 17, immagine 1 di 1
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  13. Dell Alienware 13 R3 Display Panel Replacement, Lift and Slide the Solid-State Drive: passo 18, immagine 1 di 1
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  14. Dell Alienware 13 R3 Display Panel Replacement, Press the Memory Module: passo 20, immagine 1 di 1
    • Press the memory module down until it clicks into place.
  15. Dell Alienware 13 R3 Display Panel Replacement, Popping up the Memory Module: passo 21, immagine 1 di 1
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  16. Dell Alienware 13 R3 Display Panel Replacement, Remove the Memory Module: passo 22, immagine 1 di 1
    • Slide and remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
  17. Dell Alienware 13 R3 Display Panel Replacement, Press the Memory Module Down: passo 24, immagine 1 di 1
  18. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screws: passo 25, immagine 1 di 1
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  19. Dell Alienware 13 R3 Display Panel Replacement, Using a Plastic Scribe: passo 26, immagine 1 di 1
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  20. Dell Alienware 13 R3 Display Panel Replacement, Sliding the Rear-I/O: passo 28, immagine 1 di 1
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  21. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screws: passo 30, immagine 1 di 1
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  22. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screw: passo 31, immagine 1 di 1
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  23. Dell Alienware 13 R3 Display Panel Replacement, Remove the Two Screws: passo 32, immagine 1 di 1
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  24. Dell Alienware 13 R3 Display Panel Replacement, Lift the Computer Base: passo 33, immagine 1 di 1
    • Lift the computer base from the palm-rest assembly.
  25. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Holes: passo 34, immagine 1 di 1
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  26. Dell Alienware 13 R3 Display Panel Replacement, Disconnecting the Coin-Cell Battery: passo 38, immagine 1 di 1
    • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from the system board.
  27. Dell Alienware 13 R3 Display Panel Replacement, Peeling the Coin-Cell Battery: passo 39, immagine 1 di 1
    • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  28. Dell Alienware 13 R3 Display Panel Replacement, Adhere the Coin-Cell Battery: passo 40, immagine 1 di 1
    • Adhere the NEW coin-cell battery to the palm-rest assembly.
    • Connect the coin-cell battery cable to the system board.
  29. Dell Alienware 13 R3 Display Panel Replacement, Disconnect the Left-Fan Cable: passo 42, immagine 1 di 1
    • WARNING: The heat sink may become hot during normal operation. Allow sufficient time for the heat sink to cool before you touch it.
    • CAUTION: For maximum cooling of the processor, do not touch the heat transfer areas on the heat sink. The oils in your skin can reduce the heat transfer capability of the thermal grease.
    • Disconnect the left-fan cable from the system board.
  30. Dell Alienware 13 R3 Display Panel Replacement, Disconnecting the Right-Fan Cable: passo 43, immagine 1 di 1
    • Disconnect the right-fan cable from the system board.
  31. Dell Alienware 13 R3 Display Panel Replacement, Remove the Seven Screws: passo 44, immagine 1 di 1
    • In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Lift the heat-sink assembly off the system board.
  32. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Holes: passo 46, immagine 1 di 1
    • CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
    • NOTE: The original thermal grease can be reused if the original system board and fan are reinstalled together. If either the system board or the fan is replaced, use the thermal pad provided in the kit to ensure that thermal conductivity is achieved.
    • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
    • In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Connect the right-fan cable to the respective connector on the system board.
    • Connect the left-fan cable to the respective connector on the system board.
  33. Dell Alienware 13 R3 Display Panel Replacement, Peeling the Keyboard Connector: passo 50, immagine 1 di 1
  34. Dell Alienware 13 R3 Display Panel Replacement, Lifting the Battery: passo 51, immagine 1 di 1
    • Lift the battery off the palm-rest assembly.
  35. Dell Alienware 13 R3 Display Panel Replacement, Placing the New Battery: passo 52, immagine 1 di 1
    • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
    • Using the alignment post, place the NEW battery on the palm-rest assembly.
  36. Dell Alienware 13 R3 Display Panel Replacement, Adhering the Keyboard: passo 53, immagine 1 di 1
    • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
  37. Dell Alienware 13 R3 Display Panel Replacement, Turn the Computer Over: passo 54, immagine 1 di 1
    • NOTE: Your computer’s Service Tag is stored in the system board. You must enter the Service Tag in the BIOS setup program after you replace the system board.
    • NOTE: Replacing the system board removes any changes you have made to the BIOS using the BIOS setup program. You must make the appropriate changes again after you replace the system board.
    • NOTE: Before disconnecting the cables from the system board, note the location of the connectors so that you can reconnect the cables correctly after you replace the system board.
    • CAUTION: Place the computer on a clean, flat surface.
    • Turn the computer over.
  38. Dell Alienware 13 R3 Display Panel Replacement, Disconnecting the Logo-Board Cable: passo 55, immagine 1 di 1
    • Disconnect the logo-board cable from the system board.
  39. Dell Alienware 13 R3 Display Panel Replacement, Disconnecting the Power-Button Board Cable: passo 56, immagine 1 di 1
    • Using the pull-tab, disconnect the power-button board cable from the system board.
  40. Dell Alienware 13 R3 Display Panel Replacement, Open the Latch: passo 57, immagine 1 di 1
    • Open the latch and disconnect the display cable from the system board.
  41. Dell Alienware 13 R3 Display Panel Replacement, Turn the Computer Over: passo 58, immagine 1 di 1
  42. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screw: passo 59, immagine 1 di 1
    • Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
    • Disconnect the power-adapter port cable from the system board.
  43. Dell Alienware 13 R3 Display Panel Replacement, Disconnect the Speaker Cable: passo 61, immagine 1 di 1
    • Disconnect the speaker cable from the system board.
  44. Dell Alienware 13 R3 Display Panel Replacement, Open the Latch: passo 62, immagine 1 di 1
    • Open the latch and disconnect the keyboard cable from the system board.
  45. Dell Alienware 13 R3 Display Panel Replacement, Open the Latch: passo 63, immagine 1 di 1
    • Open the latch and disconnect the keyboard-backlight cable from the system board.
  46. Dell Alienware 13 R3 Display Panel Replacement, Disconnect the Touch-Pad Cable: passo 64, immagine 1 di 1
    • Open the latch and disconnect the touch-pad cable from the system board.
  47. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screw: passo 65, immagine 1 di 1
  48. Dell Alienware 13 R3 Display Panel Replacement, Remove the two Screws: passo 66, immagine 1 di 1
    • Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
  49. Dell Alienware 13 R3 Display Panel Replacement, Lift the System Board: passo 67, immagine 1 di 1
    • Lift the system board off the palm-rest assembly.
  50. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Holes: passo 68, immagine 1 di 1
    • CAUTION: Ensure that no cables are under the system board.
    • Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
  51. Dell Alienware 13 R3 Display Panel Replacement, Replace the Two Screws: passo 69, immagine 1 di 1
    • Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
  52. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Hole: passo 70, immagine 1 di 1
    • Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
  53. Dell Alienware 13 R3 Display Panel Replacement, Replace the Screw: passo 71, immagine 1 di 1
    • Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
    • Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
  54. Dell Alienware 13 R3 Display Panel Replacement, Sliding the Keyboard-Backlight: passo 73, immagine 1 di 1
    • Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
  55. Dell Alienware 13 R3 Display Panel Replacement, Slide the Keyboard Cable: passo 74, immagine 1 di 1
    • Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
    • Connect the speaker cable to the system board.
    • Connect the power-adapter port cable to the system board.
  56. Dell Alienware 13 R3 Display Panel Replacement, Turn the Computer Over: passo 77, immagine 1 di 1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
    • Connect the power-button board cable to the system board.
    • Connect the logo-board cable to the system board.
  57. Dell Alienware 13 R3 Display Panel Replacement, Remove the Antenna Cables: passo 81, immagine 1 di 1
  58. Dell Alienware 13 R3 Display Panel Replacement, Remove the Logo-Board Cable: passo 82, immagine 1 di 1
    • Remove the logo-board cable from the routing guides on the palm-rest assembly.
  59. Dell Alienware 13 R3 Display Panel Replacement, Remove the Display Cable: passo 83, immagine 1 di 1
    • Remove the display cable from the routing guides on the palm-rest assembly.
  60. Dell Alienware 13 R3 Display Panel Replacement, Turn the Computer Over: passo 84, immagine 1 di 1
  61. Dell Alienware 13 R3 Display Panel Replacement, Remove the Four Screws: passo 85, immagine 1 di 1
    • Remove the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
  62. Dell Alienware 13 R3 Display Panel Replacement, Lifting the Display Assembly: passo 86, immagine 1 di 1
    • Lift the display assembly off the palm-rest assembly.
  63. Dell Alienware 13 R3 Display Panel Replacement, Remove the Cables: passo 87, immagine 1 di 1
    • Remove the cables from the routing holes on the palm-rest assembly.
  64. Dell Alienware 13 R3 Display Panel Replacement, Placing the Display: passo 88, immagine 1 di 1
    • Place the display assembly on a clean, flat surface.
  65. Dell Alienware 13 R3 Display Panel Replacement, Route the Cables: passo 89, immagine 1 di 1
    • Route the cables through the routing holes on the palm-rest assembly.
  66. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Holes: passo 90, immagine 1 di 1
    • Align the screw holes on the display hinges with the screw holes on the palm- rest assembly.
  67. Dell Alienware 13 R3 Display Panel Replacement, Replace the Four Screws: passo 91, immagine 1 di 1
    • Replace the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
  68. Dell Alienware 13 R3 Display Panel Replacement, Turn the Computer Over: passo 92, immagine 1 di 1
  69. Dell Alienware 13 R3 Display Panel Replacement, Route the Logo-Board Cable: passo 93, immagine 1 di 1
    • Route the logo-board cable through the routing guides on the palm-rest assembly.
  70. Dell Alienware 13 R3 Display Panel Replacement, Route the Antenna Cables: passo 94, immagine 1 di 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
  71. Dell Alienware 13 R3 Display Panel Replacement, Lift the Display Bezel: passo 96, immagine 1 di 1
    • Carefully lift the display bezel and turn it over.
  72. Dell Alienware 13 R3 Display Panel Replacement, Disconnect the Alien Head Logo: passo 97, immagine 1 di 1
    • Open the latch and disconnect the alien head logo-board cable from the logo board.
  73. Dell Alienware 13 R3 Display Panel Replacement, Peeling the Tape: passo 98, immagine 1 di 1
    • Peel off the tape that secures the logo-board cable to the logo board and disconnect the logo-board cable from the logo board.
  74. Dell Alienware 13 R3 Display Panel Replacement, Lift the Display Bezel: passo 99, immagine 1 di 1
    • Lift the display bezel off the display assembly.
  75. Dell Alienware 13 R3 Display Panel Replacement, Place the Display Assembly: passo 100, immagine 1 di 1
    • Connect the logo-board cable to the logo board.
  76. Dell Alienware 13 R3 Display Panel Replacement, Adhering the Tape: passo 102, immagine 1 di 1
    • Adhere the tape that secures the logo-board cable to the logo board.
  77. Dell Alienware 13 R3 Display Panel Replacement, Slide the Logo Board Cable: passo 103, immagine 1 di 1
    • Slide the alien head logo-board cable into the logo board and close the latch to secure the cable.
    • Carefully turn the display bezel over.
  78. Dell Alienware 13 R3 Display Panel Replacement, Align the Bezel: passo 105, immagine 1 di 1
    • Align the display bezel with the display back-cover and antenna assembly and gently snap the display bezel into place.
  79. Dell Alienware 13 R3 Display Panel Replacement, Pry the Camera Module: passo 106, immagine 1 di 1
    • Using a plastic scribe, pry the camera module from the display back-cover and antenna assembly.
  80. Dell Alienware 13 R3 Display Panel Replacement, Peel the Tape: passo 107, immagine 1 di 1
    • Peel the tape that secures the camera cable to the camera module and disconnect the camera cable from the camera module.
  81. Dell Alienware 13 R3 Display Panel Replacement, Lift the Camera Module: passo 108, immagine 1 di 1
    • Lift the camera module from the display back-cover and antenna assembly.
  82. Dell Alienware 13 R3 Display Panel Replacement, Adhere the Camera Module: passo 109, immagine 1 di 1
    • Using the alignment posts, adhere the NEW camera module to the display back-cover and antenna assembly.
  83. Dell Alienware 13 R3 Display Panel Replacement, Connect the Camera Cable: passo 110, immagine 1 di 1
    • Connect the camera cable to the camera module.
  84. Dell Alienware 13 R3 Display Panel Replacement, Adhere the Tape: passo 111, immagine 1 di 1
    • Adhere the tape that secures the camera cable to the camera module.
  85. Dell Alienware 13 R3 Display Panel Replacement, Remove the Screws: passo 112, immagine 1 di 1
    • Remove the four screws (M1.6x2) that secure the display panel to the display back-cover and antenna assembly.
  86. Dell Alienware 13 R3 Display Panel Replacement, Lift the Display Panel: passo 113, immagine 1 di 1
    • Gently lift the display panel and turn it over.
  87. Dell Alienware 13 R3 Display Panel Replacement, Peel the Tape: passo 114, immagine 1 di 1
    • Peel the tape that secures the display cable to the display panel.
    • Open the latch and disconnect the display cable from the display panel.
  88. Dell Alienware 13 R3 Display Panel Replacement: passo 116, immagine 1 di 1
    • Lift the display panel off the display back-cover.
    • Slide the display cable into the connector on the NEW display panel and close the latch to secure the cable.
    • Adhere the tape that secures the display cable to the display panel.
  89. Dell Alienware 13 R3 Display Panel Replacement, Turn the Display Panel Over: passo 119, immagine 1 di 1
    • Turn the display panel over and gently place it on the display back-cover.
    • CAUTION: Ensure that no cables are under the display panel.
  90. Dell Alienware 13 R3 Display Panel Replacement, Align the Screw Holes: passo 120, immagine 1 di 1
    • Align the screw holes on the display panel with the screw holes on the display back-cover and antenna assembly.
  91. Dell Alienware 13 R3 Display Panel Replacement, Replace the Four Screws: passo 121, immagine 1 di 1
    • Replace the four screws (M1.6x2) that secure the display panel to the display back-cover and antenna assembly.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
3 Commenti
some steps are repetitive or out of order.
Lee - Replica
Note that this procedure is to follow if you’r not replacing the screen by the exact same model your laptop came with.
Screen ribbon cable sare different for every screens so you can not ‘‘plug and play’’ a 1080p screen if you had a 720p display, you need this complete teardown to replace de cable.
If you’r just replacing a broken screen by the same model it doesn’t require a complete teardown of the device because you keep the same screen ribbon cable.
Yoann Mourot - Replica
Noted, whelp, I only saw this AFTER tearing it apart. Good learning experience I guess.
Matt B -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,091
