Salta al contenuto principale
Dell Alienware 13 R3 Base Cover Replacement
Cosa ti serve
  1. Dell Alienware 13 R3 Base Cover Replacement, Loosen the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Base Cover Replacement, Pry the Base Cover: passo 2, immagine 1 di 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Base Cover Replacement, Lift the Base Cover: passo 3, immagine 1 di 1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Base Cover Replacement, Disconnect the Battery Cable: passo 4, immagine 1 di 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Base Cover Replacement, Slide the Tabs: passo 7, immagine 1 di 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Base Cover Replacement, Tighten the Five Captive Screws: passo 8, immagine 1 di 1
    • Tighten the five captive screws that secure the base cover to the computer base.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 579
