Introduzione
In this guide, we will show you how to remove and replace the Display Panel.
Strumenti
Ricambi
Nessuna parte specificata.
Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
Using the pull tab, disconnect the solid-state drive cable from the system board.
Remove the screws that secure the solid-state drive assembly to the computer base.
Lift the solid-state drive assembly off the computer base.
Make sure the screws are off the solid-state assembly.
Slide the new solid-state drive into the solid-state drive assembly.
Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
Replace the screws that secure the solid-state drive assembly to the computer base.
Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
Remove the screws that secure the palm-rest assembly to the computer base.
Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
Turn the computer over and open the display as far as possible.
Using a plastic scribe, pry up along the edges of the palm-rest assembly.
Gently lift the palm-rest assembly and turn it over.
Lift the connector latch and disconnect the power-button board cable from the system board.
Remove the Keyboard.
Remove the power-button board.
Remove the status-light board.
Remove the touchpad.
Replace the touchpad.
Replace the status-light board.
Replace the power-button board.
Replace the keyboard.
Connect the power-button board cable to the system board.
Align the palm-rest assembly on the computer base and snap it into place.
Close the display and turn the computer over.
Replace the screws that secure the palm-rest assembly to the computer base.
Connect the keyboard cable and the keyboard-backlight cable to the system board.
Remove the screws that secure the hinge caps to the display hinges.
Remove the screw that secures the wireless-card bracket to the wireless card.
Disconnect the antenna cables from the wireless card.
Peel off the adhesive tapes that secure the antenna cables to the system board.
Remove the antenna cables from the routing guides on the display hinges.
Lift the connector latch and disconnect the display cable from the system board.
Remove the display cable from the routing guides on the display hinges.
Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
Remove the screws that secure the display assembly to the computer base.
Align the screw holes on the display hinges with the screw holes on the computer base.
Replace the screws that secure the display hinges to the computer base.
Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
Route the display cable through the routing guides on the display hinge.
Slide the display cable into the connector on the system board and press down the latch to secure the cable.
Route the antenna cables through the routing guides on the display hinges.
Adhere the adhesive tapes that secure the antenna cables to the system board.
Replace the screw that secures the wireless-card bracket to the wireless card.
Align the screw holes on the hinge caps with the screw holes on the display hinges.
Replace the screws that secure the hinge caps to the display hinges.
Remove the screws that secure the display panel to the display back-cover.
Lift the connector latch and disconnect the display cable from the display panel.
Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable.
Align the screw holes on the display panel with the screw holes on the display back-cover.
Replace the screws that secure the display panel to the display back-cover.
