Salta al contenuto principale
Dell Alienware 13 Display Panel Replacement
Cosa ti serve
  1. Dell Alienware 13 Display Panel Replacement, Base Panel: passo 1, immagine 1 di 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Display Panel Replacement: passo 2, immagine 1 di 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Display Panel Replacement: passo 3, immagine 1 di 3 Dell Alienware 13 Display Panel Replacement: passo 3, immagine 2 di 3 Dell Alienware 13 Display Panel Replacement: passo 3, immagine 3 di 3
    • Remove the small access panel using a heavy duty spudger.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  4. Dell Alienware 13 Display Panel Replacement, Pull Tab: passo 5, immagine 1 di 1
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  5. Dell Alienware 13 Display Panel Replacement, Disconnecting the State Drive: passo 6, immagine 1 di 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  6. Dell Alienware 13 Display Panel Replacement, Remove Screws: passo 7, immagine 1 di 1
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  7. Dell Alienware 13 Display Panel Replacement, Solid-State Drive Assembly Lift: passo 8, immagine 1 di 2 Dell Alienware 13 Display Panel Replacement, Solid-State Drive Assembly Lift: passo 8, immagine 2 di 2
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  8. Dell Alienware 13 Display Panel Replacement, Slide and Lift: passo 9, immagine 1 di 1
    • Slide and lift the solid-state drive off the solid-state assembly.
  9. Dell Alienware 13 Display Panel Replacement, Replacing the Solid-State Drive: passo 10, immagine 1 di 1
    • Slide the new solid-state drive into the solid-state drive assembly.
  10. Dell Alienware 13 Display Panel Replacement, Replace the Screw: passo 11, immagine 1 di 1
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  11. Dell Alienware 13 Display Panel Replacement, Screw Align: passo 12, immagine 1 di 1
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  12. Dell Alienware 13 Display Panel Replacement, Screw Replacement: passo 13, immagine 1 di 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  13. Dell Alienware 13 Display Panel Replacement, Connecting the Drive: passo 14, immagine 1 di 1
    • Connect the solid-state drive cable to the system board.
  14. Dell Alienware 13 Display Panel Replacement, Aligning Screws: passo 15, immagine 1 di 1
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  15. Dell Alienware 13 Display Panel Replacement, Replacing Screws: passo 16, immagine 1 di 1
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  16. Dell Alienware 13 Display Panel Replacement, Disconnecting the Keyboard: passo 17, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  17. Dell Alienware 13 Display Panel Replacement, Removing the Screws: passo 18, immagine 1 di 2 Dell Alienware 13 Display Panel Replacement, Removing the Screws: passo 18, immagine 2 di 2
    • Remove the screws that secure the palm-rest assembly to the computer base.
  18. Dell Alienware 13 Display Panel Replacement, Popping out the Palm-Rest Assembly: passo 19, immagine 1 di 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  19. Dell Alienware 13 Display Panel Replacement, Turn the Computer Over: passo 20, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
  20. Dell Alienware 13 Display Panel Replacement, Prying the Edges: passo 21, immagine 1 di 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  21. Dell Alienware 13 Display Panel Replacement, Lifting the Palm-Rest Assembly: passo 22, immagine 1 di 1
    • Gently lift the palm-rest assembly and turn it over.
  22. Dell Alienware 13 Display Panel Replacement, Disconnecting the Power-Board Cable: passo 23, immagine 1 di 2 Dell Alienware 13 Display Panel Replacement, Disconnecting the Power-Board Cable: passo 23, immagine 2 di 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  23. Dell Alienware 13 Display Panel Replacement, Connecting the Power-Button Board Cable: passo 26, immagine 1 di 1
    • Connect the power-button board cable to the system board.
  24. Dell Alienware 13 Display Panel Replacement, Aligning the Palm-Rest Assembly.: passo 27, immagine 1 di 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  25. Dell Alienware 13 Display Panel Replacement, Open the Display: passo 31, immagine 1 di 1
  26. Dell Alienware 13 Display Panel Replacement, Removing the Screws: passo 32, immagine 1 di 2 Dell Alienware 13 Display Panel Replacement, Removing the Screws: passo 32, immagine 2 di 2
    • Remove the screws that secure the hinge caps to the display hinges.
  27. Dell Alienware 13 Display Panel Replacement, Lift the Hinge Caps: passo 33, immagine 1 di 1
    • Slide and lift the hinge caps off the display hinges.
  28. Dell Alienware 13 Display Panel Replacement, Close the Display: passo 34, immagine 1 di 1
  29. Dell Alienware 13 Display Panel Replacement, Peeling the Adhesive Tape: passo 35, immagine 1 di 1
    • Peel off the adhesive tape from the wireless card.
  30. Dell Alienware 13 Display Panel Replacement, Remove the Screw: passo 36, immagine 1 di 1
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  31. Dell Alienware 13 Display Panel Replacement, Disconnecting the Antenna Cables: passo 37, immagine 1 di 1
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  32. Dell Alienware 13 Display Panel Replacement, Peeling the Adhesive Tapes: passo 39, immagine 1 di 1
    • Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Make note of the cable routing before removing any cable from its routing guide.
  33. Dell Alienware 13 Display Panel Replacement, Removing the Antenna Cables: passo 40, immagine 1 di 1
    • Remove the antenna cables from the routing guides on the display hinges.
  34. Dell Alienware 13 Display Panel Replacement, Disconnecting the Display Cable: passo 41, immagine 1 di 2 Dell Alienware 13 Display Panel Replacement, Disconnecting the Display Cable: passo 41, immagine 2 di 2
    • Lift the connector latch and disconnect the display cable from the system board.
  35. Dell Alienware 13 Display Panel Replacement, Removing the Display Cable: passo 42, immagine 1 di 1
    • Remove the display cable from the routing guides on the display hinges.
  36. Dell Alienware 13 Display Panel Replacement, Disconnecting the Logo-Board Cable: passo 43, immagine 1 di 1
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  37. Dell Alienware 13 Display Panel Replacement, Removing the Screws: passo 44, immagine 1 di 1
    • Remove the screws that secure the display assembly to the computer base.
  38. Dell Alienware 13 Display Panel Replacement, Lifting the Display Assembly: passo 45, immagine 1 di 1
    • Lift the display assembly off the computer base.
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  39. Dell Alienware 13 Display Panel Replacement, Replacing the Screws: passo 47, immagine 1 di 1
    • Replace the screws that secure the display hinges to the computer base.
  40. Dell Alienware 13 Display Panel Replacement, Connecting the Logo-Board Cable: passo 48, immagine 1 di 1
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  41. Dell Alienware 13 Display Panel Replacement, Routing the Display Cable: passo 49, immagine 1 di 1
    • Route the display cable through the routing guides on the display hinge.
  42. Dell Alienware 13 Display Panel Replacement, Sliding the Display Cable: passo 50, immagine 1 di 1
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
  43. Dell Alienware 13 Display Panel Replacement, Route the Antenna Cables: passo 51, immagine 1 di 1
    • Route the antenna cables through the routing guides on the display hinges.
  44. Dell Alienware 13 Display Panel Replacement, Adhering the Tapes: passo 52, immagine 1 di 1
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
  45. Dell Alienware 13 Display Panel Replacement, Connecting the Antenna Cables: passo 54, immagine 1 di 1
    • Connect the antenna cables to the wireless card.
  46. Dell Alienware 13 Display Panel Replacement, Replace the Screw: passo 55, immagine 1 di 2 Dell Alienware 13 Display Panel Replacement, Replace the Screw: passo 55, immagine 2 di 2
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  47. Dell Alienware 13 Display Panel Replacement, Adhering the Adhesive Tape: passo 56, immagine 1 di 1
    • Adhere the adhesive tape to the wireless card.
  48. Dell Alienware 13 Display Panel Replacement, Align the Screw Holes: passo 58, immagine 1 di 1
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  49. Dell Alienware 13 Display Panel Replacement, Remove the Screws: passo 60, immagine 1 di 3 Dell Alienware 13 Display Panel Replacement, Remove the Screws: passo 60, immagine 2 di 3 Dell Alienware 13 Display Panel Replacement, Remove the Screws: passo 60, immagine 3 di 3
    • Remove the screws that secure the display panel to the display back-cover.
  50. Dell Alienware 13 Display Panel Replacement, Lift the Display Panel: passo 61, immagine 1 di 1
    • Gently lift the display panel and turn it over.
  51. Dell Alienware 13 Display Panel Replacement, Lift the Connector Latch: passo 62, immagine 1 di 3 Dell Alienware 13 Display Panel Replacement, Lift the Connector Latch: passo 62, immagine 2 di 3 Dell Alienware 13 Display Panel Replacement, Lift the Connector Latch: passo 62, immagine 3 di 3
    • Lift the connector latch and disconnect the display cable from the display panel.
  52. Dell Alienware 13 Display Panel Replacement, Securing the Cable: passo 63, immagine 1 di 3 Dell Alienware 13 Display Panel Replacement, Securing the Cable: passo 63, immagine 2 di 3 Dell Alienware 13 Display Panel Replacement, Securing the Cable: passo 63, immagine 3 di 3
    • Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable.
    • Turn the display panel over.
  53. Dell Alienware 13 Display Panel Replacement, Align the Screw Holes: passo 65, immagine 1 di 1
    • Align the screw holes on the display panel with the screw holes on the display back-cover.
  54. Dell Alienware 13 Display Panel Replacement, Replace the Screws: passo 66, immagine 1 di 1
    • Replace the screws that secure the display panel to the display back-cover.
Conclusione
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 364
