Salta al contenuto principale
Dell Adamo 13 Keyboard Replacement
Cosa ti serve
  1. Dell Adamo 13 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Keyboard Replacement: passo 3, immagine 1 di 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Keyboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
  5. Dell Adamo 13 Keyboard Replacement: passo 5, immagine 1 di 3 Dell Adamo 13 Keyboard Replacement: passo 5, immagine 2 di 3 Dell Adamo 13 Keyboard Replacement: passo 5, immagine 3 di 3
    • Remove all the connections to the circuit board on top and underneath.
    • Use caution when removing connections to prevent damage.
    • Remove the motherboard from the device.
  6. Dell Adamo 13 Keyboard Replacement, Keyboard: passo 6, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove eight 2 mm screws securing the keypad to the device.
  7. Dell Adamo 13 Keyboard Replacement: passo 7, immagine 1 di 2 Dell Adamo 13 Keyboard Replacement: passo 7, immagine 2 di 2
    • Gently lift the keypad out of the laptop mainframe.
Conclusione
Tyler Pourmand
Membro da: 10/25/21
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 150
