Salta al contenuto principale
Dell Adamo 13 Dell Solid State Drive Replacement
Cosa ti serve
  1. Dell Adamo 13 Dell Solid State Drive Replacement, Battery: passo 1, immagine 1 di 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Dell Solid State Drive Replacement: passo 2, immagine 1 di 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Dell Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Dell Solid State Drive Replacement, SSD: passo 4, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws securing the SSD to the motherboard.
Conclusione
Joshua Turner
Membro da: 10/25/21
73 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 208
