Salta al contenuto principale
Dell AC511 Rear Panel Replacement
Cosa ti serve
  1. Dell AC511 Rear Panel Replacement, Front Panel: passo 1, immagine 1 di 3 Dell AC511 Rear Panel Replacement, Front Panel: passo 1, immagine 2 di 3 Dell AC511 Rear Panel Replacement, Front Panel: passo 1, immagine 3 di 3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Rear Panel Replacement: passo 2, immagine 1 di 2 Dell AC511 Rear Panel Replacement: passo 2, immagine 2 di 2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Rear Panel Replacement: passo 3, immagine 1 di 2 Dell AC511 Rear Panel Replacement: passo 3, immagine 2 di 2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Rear Panel Replacement, Speaker: passo 4, immagine 1 di 2 Dell AC511 Rear Panel Replacement, Speaker: passo 4, immagine 2 di 2
    • Follow the three wires connected to the speaker to find where they connect to the circuit board.
    • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
  5. Dell AC511 Rear Panel Replacement, Volume Knob: passo 5, immagine 1 di 1
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
  6. Dell AC511 Rear Panel Replacement: passo 6, immagine 1 di 1
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
  7. Dell AC511 Rear Panel Replacement, Rear Panel: passo 7, immagine 1 di 1
    • Use the pointy end of the spudger to push the audio jack ports into the device to disconnect the secondary circuit board from the rear ranel.
    • Do not use too much force. Pushing too hard will risk breaking the audio jacks.
  8. Dell AC511 Rear Panel Replacement: passo 8, immagine 1 di 2 Dell AC511 Rear Panel Replacement: passo 8, immagine 2 di 2
    • Remove the 10 mm bolt using a socket wrench with a 10-11 mm socket.
    • After removing the bolt, pull the disconnected volume control board out.
Conclusione
William Cook
Membro da: 03/19/24
617 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 19
Tutti i Tempi: 112
