Salta al contenuto principale
Dell AC511 Front Panel Replacement
Cosa ti serve
  1. Dell AC511 Front Panel Replacement, Front Panel: passo 1, immagine 1 di 3 Dell AC511 Front Panel Replacement, Front Panel: passo 1, immagine 2 di 3 Dell AC511 Front Panel Replacement, Front Panel: passo 1, immagine 3 di 3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Front Panel Replacement: passo 2, immagine 1 di 2 Dell AC511 Front Panel Replacement: passo 2, immagine 2 di 2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Front Panel Replacement: passo 3, immagine 1 di 2 Dell AC511 Front Panel Replacement: passo 3, immagine 2 di 2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
Conclusione
William Cook
Membro da: 03/19/24
653 Reputazione
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 48
Tutti i Tempi: 900
