Introduzione
You can follow this guide to replace your Dell Inspiron 15-7569's RAM if you would like to improve performance speed.
Cosa ti serve
Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
After removing the screws, remove the back cover using a plastic or metal spudger.
Locate the two black RAM "flaps" (pictured)
Lift each flap and push out on the metal clamps holding the RAM
The RAM will "pop" and "rise" when properly removed
