Salta al contenuto principale
Definitive Technology W7 Speaker Replacement
Cosa ti serve
  1. Definitive Technology W7 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Use the metal spudger to pry off the panel at the top of the device.
    • The top panel has the device logo in the center.
    • Use the flat end of the metal spudger and place it between the gaps of the top panel and slowly pry the panel off.
  2. Definitive Technology W7 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the thirteen Phillips #0 screws.
  3. Definitive Technology W7 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the black panel.
  4. Definitive Technology W7 Speaker Replacement: passo 4, immagine 1 di 2 Definitive Technology W7 Speaker Replacement: passo 4, immagine 2 di 2
    • After you remove the black panel, you will see that the device is covered with a gray mesh, secured with a drawstring.
    • Flick the switch on the middle of the lock down to loosen the sack.
  5. Definitive Technology W7 Speaker Replacement: passo 5, immagine 1 di 1
    • After you have flicked the switch loosen the sack and pull the sack down which will reveal the speaker.
  6. Definitive Technology W7 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
  7. Definitive Technology W7 Speaker Replacement: passo 7, immagine 1 di 1
    • Gently lift the top cover off the device.
  8. Definitive Technology W7 Speaker Replacement: passo 8, immagine 1 di 1
    • If you now look inside the device, you will see the speaker which is the large cylinder on the inner side of the device.
  9. Definitive Technology W7 Speaker Replacement: passo 9, immagine 1 di 2 Definitive Technology W7 Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the four Phillips #0 screws around the speaker holding it in place.
    • Now lay the device on its side with the speaker facing upward, then unscrew the screws around the speaker.
  10. Definitive Technology W7 Speaker Replacement: passo 10, immagine 1 di 1
    • Stand the device upright and carefully pull the speaker out of the device with the wires still intact.
  11. Definitive Technology W7 Speaker Replacement: passo 11, immagine 1 di 1
    • Now grab the end of the wire connecting the device to the speaker itself.
    • Slowly and carefully pull the wires away from the speaker.
Conclusione
Jamari Brewster
Membro da: 10/26/22
193 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 227
