Salta al contenuto principale
Decorative Light Fixture Lightbulb Replacement
Cosa ti serve
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: passo 1, immagine 1 di 1
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: passo 2, immagine 1 di 2 Decorative Light Fixture Lightbulb Replacement: passo 2, immagine 2 di 2
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: passo 3, immagine 1 di 1
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: passo 4, immagine 1 di 2 Decorative Light Fixture Lightbulb Replacement: passo 4, immagine 2 di 2
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: passo 5, immagine 1 di 1
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: passo 6, immagine 1 di 2 Decorative Light Fixture Lightbulb Replacement: passo 6, immagine 2 di 2
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: passo 7, immagine 1 di 2 Decorative Light Fixture Lightbulb Replacement: passo 7, immagine 2 di 2
    • Hold onto the fixture, and screw it back in with the screwdriver.
Linea Traguardo
Jordan Parry
Membro da: 03/30/21
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 259
