Salta al contenuto principale
DeWalt_D26451 Brake Replacement
Cosa ti serve
  1. DeWalt_D26451 Brake Replacement, Pad: passo 1, immagine 1 di 3 DeWalt_D26451 Brake Replacement, Pad: passo 1, immagine 2 di 3 DeWalt_D26451 Brake Replacement, Pad: passo 1, immagine 3 di 3
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: passo 2, immagine 1 di 2 DeWalt_D26451 Brake Replacement: passo 2, immagine 2 di 2
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: passo 3, immagine 1 di 1
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: passo 4, immagine 1 di 1
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: passo 5, immagine 1 di 1
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,046
