Salta al contenuto principale
DeWalt DWE4011 Power Switch Replacement
Cosa ti serve
  1. DeWalt DWE4011 Power Switch Replacement, Power Switch: passo 1, immagine 1 di 1
    • Turn to the bottom of the device and remove the 1 1/4" screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Power Switch Replacement: passo 2, immagine 1 di 1
    • Remove the outer casing by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Power Switch Replacement: passo 3, immagine 1 di 1
    • Unscrew the pin that is holding the main power cord in place and remove the cord.
  4. DeWalt DWE4011 Power Switch Replacement: passo 4, immagine 1 di 2 DeWalt DWE4011 Power Switch Replacement: passo 4, immagine 2 di 2
    • Pull back the tab holding the switch box in place using a nylon spudger. There is one on top and bottom shown in the image.
  5. DeWalt DWE4011 Power Switch Replacement: passo 5, immagine 1 di 1
    • Remove the switch box entirely from its normal position. Gently pull off the connections from the switch box to the motor.
  6. DeWalt DWE4011 Power Switch Replacement: passo 6, immagine 1 di 2 DeWalt DWE4011 Power Switch Replacement: passo 6, immagine 2 di 2
    • Using a small Phillips head screwdriver, remove the screws that hold the white colored wires from the power cord in place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,212
