Introduzione
When replacing electrical components on any device careful consideration must be taken to reduce risk of shock. Be sure the cord is not plugged into a power source before proceeding with this replacement guide. If the cord is cut, this should not be an issue. Reasons you might need follow this guide include: damaged power cord, or the grinder wont turn on.
Cosa ti serve
Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
Altre 4 persone hanno completato questa guida.
