Salta al contenuto principale
DeWalt DWE4011 Power Cable Replacement
Cosa ti serve
  1. DeWalt DWE4011 Power Cable Replacement, Power Cord: passo 1, immagine 1 di 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
  2. DeWalt DWE4011 Power Cable Replacement: passo 2, immagine 1 di 2 DeWalt DWE4011 Power Cable Replacement: passo 2, immagine 2 di 2
    • Remove bottom casing by separating the end handle away from the main casing.
  3. DeWalt DWE4011 Power Cable Replacement: passo 3, immagine 1 di 2 DeWalt DWE4011 Power Cable Replacement: passo 3, immagine 2 di 2
    • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
  4. DeWalt DWE4011 Power Cable Replacement: passo 4, immagine 1 di 1
    • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
  5. DeWalt DWE4011 Power Cable Replacement: passo 5, immagine 1 di 2 DeWalt DWE4011 Power Cable Replacement: passo 5, immagine 2 di 2
    • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
  6. DeWalt DWE4011 Power Cable Replacement: passo 6, immagine 1 di 2 DeWalt DWE4011 Power Cable Replacement: passo 6, immagine 2 di 2
    • Locate the terminals with the two white cables attached and disconnect both.
    • These cables are connected to the outer terminals; connect as such during reassembly.
  7. DeWalt DWE4011 Power Cable Replacement: passo 7, immagine 1 di 2 DeWalt DWE4011 Power Cable Replacement: passo 7, immagine 2 di 2
    • Remove the entirety of the cable housing from the device casing.
    • The two wires coming from the power cable should still be connected to electrical housing at this point.
  8. DeWalt DWE4011 Power Cable Replacement: passo 8, immagine 1 di 1
    • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
    • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
Conclusione
Altre 4 persone hanno completato questa guida.
Un commento
Where can I find a replacement power cord?
Ethan Sligar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 82
Tutti i Tempi: 3,253
