Salta al contenuto principale
DeWalt DWE4011 Carbon Brushes Replacement
Cosa ti serve
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: passo 1, immagine 1 di 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: passo 2, immagine 1 di 1
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: passo 3, immagine 1 di 2 DeWalt DWE4011 Carbon Brushes Replacement: passo 3, immagine 2 di 2
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: passo 4, immagine 1 di 1
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: passo 5, immagine 1 di 1
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: passo 6, immagine 1 di 2 DeWalt DWE4011 Carbon Brushes Replacement: passo 6, immagine 2 di 2
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
Conclusione
Congratulations! To put your device back together, simply reverse the above steps.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,274
