Salta al contenuto principale
DeWalt DWE4011 Brush Spring Replacement
Cosa ti serve
  1. DeWalt DWE4011 Brush Spring Replacement, Brush Spring: passo 1, immagine 1 di 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Brush Spring Replacement: passo 2, immagine 1 di 1
    • Remove outer casing by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Brush Spring Replacement: passo 3, immagine 1 di 1
    • Locate the brush springs on either side of the device.
  4. DeWalt DWE4011 Brush Spring Replacement: passo 4, immagine 1 di 1
    • Using an iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Brush Spring Replacement: passo 5, immagine 1 di 1
    • Remove the spring by sliding it out of the center post (use an iFixit opening tool if needed).
    • When replacing the spring you need to tension it. Watch this video at 1:55 to see how.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,159
