Introduzione
This guide will show you how to replace the trigger pack. This is necessary if the battery is charged but the drill will not start or if the battery is fine but the drill will not spin.
Cosa ti serve
First remove the seven 21mm screws using a Torx T15 screw bit.
Then use a Torx T10 screw bit to remove the remaining 18mm screw.
After removing all of the screws, lift the cover off.
Un commento
We supply best replacement Dewalt power tool batteries at a wholesale price in Australia. Cordless drill batteries for Dewalt are producted with high test safe circle and chips that give different capacities. We pormise the replacement Dewalt batteries are 100% compatible with the orginal porducts. Full 1 year quality assurance & 30 days money back gurantee! Select cheap Dewalt cordless drill battery by models at http://www.drill-battery-au.com/bestbatt...
