Salta al contenuto principale
DeWalt DW997 Trigger Replacement
Cosa ti serve
  1. DeWalt DW997 Trigger Replacement, Trigger: passo 1, immagine 1 di 2 DeWalt DW997 Trigger Replacement, Trigger: passo 1, immagine 2 di 2
    • First remove the seven 21mm screws using a Torx T15 screw bit.
    • Then use a Torx T10 screw bit to remove the remaining 18mm screw.
    • After removing all of the screws, lift the cover off.
    • Do not attempt to pry the covers apart; doing so can cause the covers to crack.
  2. DeWalt DW997 Trigger Replacement: passo 2, immagine 1 di 1
    • Carefully remove the trigger pack by lifting the pack straight up.
  3. DeWalt DW997 Trigger Replacement: passo 3, immagine 1 di 1
    • The final step is to pull the wires off of the trigger by pulling the wire heads.
    • Be careful while taking off the wires as they can tear.
Conclusione
Un commento
We supply best replacement Dewalt power tool batteries at a wholesale price in Australia. Cordless drill batteries for Dewalt are producted with high test safe circle and chips that give different capacities. We pormise the replacement Dewalt batteries are 100% compatible with the orginal porducts. Full 1 year quality assurance & 30 days money back gurantee! Select cheap Dewalt cordless drill battery by models at http://www.drill-battery-au.com/bestbatt...
drillbatterycomau - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,907
