Salta al contenuto principale
DeWalt DW997 Motor Replacement
Cosa ti serve
  1. DeWalt DW997 Motor Replacement, Speed Switch: passo 1, immagine 1 di 2 DeWalt DW997 Motor Replacement, Speed Switch: passo 1, immagine 2 di 2
    • Remove seven 21 mm Torx T15 screws.
    • Remove one 18 mm Torx T10 screw.
    • After removing all screws, lift up the top yellow cover.
    • The yellow cover should easily lift up, if not, check for unscrewed screws.
    • Do not pry the two yellow covers apart, they can crack.
  2. DeWalt DW997 Motor Replacement: passo 2, immagine 1 di 1
    • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
  3. DeWalt DW997 Motor Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
  4. DeWalt DW997 Motor Replacement: passo 4, immagine 1 di 1
    • Remove the other leg manually, it should easily come out.
  5. DeWalt DW997 Motor Replacement, Motor: passo 5, immagine 1 di 2 DeWalt DW997 Motor Replacement, Motor: passo 5, immagine 2 di 2
    • Use a Torx T10 screw bit to remove the four 11mm screws around the motor.
  6. DeWalt DW997 Motor Replacement: passo 6, immagine 1 di 2 DeWalt DW997 Motor Replacement: passo 6, immagine 2 di 2
    • Pull off the two wires that connect the motor to the trigger.
    • Be careful while pulling the wires as they can tear.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,253
