Salta al contenuto principale
DeWalt DW938 Clam Shell Replacement
Cosa ti serve
  1. DeWalt DW938 Clam Shell Replacement, Clam Shell: passo 1, immagine 1 di 3 DeWalt DW938 Clam Shell Replacement, Clam Shell: passo 1, immagine 2 di 3 DeWalt DW938 Clam Shell Replacement, Clam Shell: passo 1, immagine 3 di 3
    • Use a torque bit screw driver to remove the T10 18.3 mm screw on the handle.
    • Use a torque bit screw driver to remove 6 T10 21.5 mm screws on the handle.
    • Insure power source is removed from tool.
    • Insure blade is removed from tool.
  2. DeWalt DW938 Clam Shell Replacement: passo 2, immagine 1 di 1
    • Carefully cut the safety sticker with a blade along the seam.
  3. DeWalt DW938 Clam Shell Replacement: passo 3, immagine 1 di 1
    • Remove the Clam Shell from the handle unit.
Conclusione
IUPUI, Team S4-G4, Baechle Spring 2017 Membro di IUPUI, Team S4-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G4
4 Membri
3 Guide realizzate
Un commento
do you know where I can find a clam shell just like this one?
file:///C:/Users/Tony/Desktop/clam%20shell1.jpg
Tony Lacour - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 17
Tutti i Tempi: 600
