Salta al contenuto principale
DeWalt DW936 Saw Blade Replacement
  1. DeWalt DW936 Saw Blade Replacement, Saw Blade: passo 1, immagine 1 di 1
    • Take out the Allen Key that is located on the front of the saw below the smooth control handle on the top of the saw.
  2. DeWalt DW936 Saw Blade Replacement: passo 2, immagine 1 di 1
    • Use the Allen Key to replace to loosen the bolt where the center of the saw is/would be.
  3. DeWalt DW936 Saw Blade Replacement: passo 3, immagine 1 di 1
    • Remove the circular nut that is used to hold the saw blade in place. It slide right off.
  4. DeWalt DW936 Saw Blade Replacement: passo 4, immagine 1 di 1
    • Lift up the plastic cover on the bottom to expose the bottom slot on the saw.
  5. DeWalt DW936 Saw Blade Replacement: passo 5, immagine 1 di 1
    • Place blade on the peg in the middle of the saw. The peg has two flat sides as does the saw hole to prevent slipping when spinning.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 8-2, Banghart Winter 2017 Membro di Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,831
