Salta al contenuto principale
DeWalt DW936 Boot Replacement
Cosa ti serve
  1. DeWalt DW936 Boot Replacement, Plastic Cover: passo 1, immagine 1 di 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Boot Replacement: passo 2, immagine 1 di 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Boot Replacement: passo 3, immagine 1 di 1
    • Remove Allen Key.
  4. DeWalt DW936 Boot Replacement: passo 4, immagine 1 di 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Boot Replacement: passo 5, immagine 1 di 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Boot Replacement: passo 6, immagine 1 di 1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Boot Replacement, Boot: passo 7, immagine 1 di 1
    • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
  8. DeWalt DW936 Boot Replacement: passo 8, immagine 1 di 1
    • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
  9. DeWalt DW936 Boot Replacement: passo 9, immagine 1 di 1
    • Pull the blade away from the body of the saw causing the blade and boot to detach.
  10. DeWalt DW936 Boot Replacement: passo 10, immagine 1 di 1
    • Pull the boot downwards away from the blade to detach it.
Conclusione
Cal Poly, Team 8-2, Banghart Winter 2017 Membro di Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 478
