Salta al contenuto principale
DeWalt DW920 Motor Replacement
Cosa ti serve
  1. DeWalt DW920 Motor Replacement, Disassembly: passo 1, immagine 1 di 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: passo 2, immagine 1 di 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: passo 3, immagine 1 di 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: passo 4, immagine 1 di 1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: passo 5, immagine 1 di 1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: passo 6, immagine 1 di 1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Conclusione
Stephen Rada
Membro da: 03/11/16
433 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 810
